Displays information about the status of the LDP sessions and hello adjacencies for all LDP peers.
| ipaddress | Display session and hello adjacency information for a single LDP peer. |
| detail | Display additional detailed information related to the session and adjacencies. |
N/A.
Specifying the LDP peer's ipaddress displays session and hello adjacency information for a single LDP peer. When the detail keyword is specified, additional detailed information related to the session and adjacencies is displayed.
show mpls label Field Definitions describes the display fields that appear when this command is entered.
| Field | Definition |
| IP Address | Local IP address, which is used as the LSR-ID. |
| LDP Peer | LDP identifier of LDP peer. |
| State | Displays the state of the Initialization State Machine as described in RFC 3036, LDP Specification. The states are: NonExistent, Initialized, OpenRec, OpenSent, and Operational. |
| Uptime | Displays the total time the session has been operational. |
| Adjacencies | Displays the number of active adjacencies with the LDP peer. |
| Index | The Entity Index used in the LDP Entity Table MIB. |
| Targeted Peer | The IP address of the peer used in Extended Discovery. If this is not a targeted peer (Basic Discovery was used), this field displays Not Targeted. |
| Attempted Sessions | This and other counters are described in RFC 3036, LDP Specification. |
| Shutdown Notifications | This and other counters are described in RFC 3036, LDP Specification. |
| Peer | IP address of peer. |
| Peer Label Space | The label space as given by the peer and derived from the LDP Identifier. A zero value represents the global or per-platform label space. A non-zero value represents a per interface label space. |
| Session State | Displays the state of the Initialization State Machine as described in RFC 3036, LDP Specification. The states are: NonExistent, Initialized, OpenRec, OpenSent, and Operational. |
| Session Uptime | Displays the total time the session has been operational. |
| Discontinuity Time | The system uptime for the most recent period after which one or more of the session's counters suffered a discontinuity. |
| Keep Alive Hold Timer | Displays the configured keep alive hold timer value and the remaining hold time. |
| Label Distribution Method | Label Distribution Method is either DU (Downstream Unsolicited) or DOD (Downstream On Demand), as described in RFC 3036, LDP Specification. |
| Max PDU Length | The maximum allowable length for LDP PDUs (Protocol Data Units) for this session. |
| Unknown Msg Type Errors | The number of messages received for this session without a recognized message type and without the ignore bit set. |
| Unknown TLV Errors | The number of TLVs received for this session without a recognized TLV type and without the ignore bit set. |
| Next Hop Addr(s) | A list of next hop addresses received from the peer through LDP address messages. |
The following command displays MPLS LDP session information for the LDP entity 11.100.100.30:
Mariner3.59 # show mpls ldp peer IP Address LDP Peer State Uptime Adjacencies 11.100.100.30 11.100.100.55:0 Operational 0d:14h:51m:53s 1 11.100.100.30 14.4.0.99:15 Operational 0d:1h:0m:43s 1 11.100.100.30 14.4.0.99:16 Operational 0d:0h:34m:51s 1 Adjacencies: Index : 1 Attempted Sessions : 1 Targeted Peer : 11.100.100.210:0 Shutdown Notifications : Sent 0 Rcvd 0 Mariner3.32 # show mpls ldp peer detail Peer: 11.100.100.55 Peer label space: 0 (global) Session State : Operational Session Uptime : 0d:0h:13m:41s ... Peer: 14.4.0.99 Peer label space: 15 Session State : Operational Session Uptime : 0d:0h:57m:4s ... Peer: 14.4.0.99 Peer label space: 16 Session State : Operational Session Uptime : 0d:0h:31m:12s ... * DUT65.2 # show mpls ldp peer detail Peer: 11.100.100.210 Peer Label Space: 0 (global) Session State : Operational Session Uptime : 0d:0h:6m:30s Discontinuity Time : 34677 Keep Alive Hold Timer : 40 (remaining: 37.86) Label Distribution Method : DU Max PDU Length : 4096 Unknown Msg Type Errors : 0 Unknown TLV Errors : 0 Next Hop Addr(s) : 11.100.100.210 12.20.20.210 Adjacencies: Index : 1 Attempted Sessions : 0 Targeted Peer : 11.100.100.210:0 Shutdown Notifications : Sent 0 Rcvd 0 Admin Status : Enabled No Hello Errors : 0 Operational Status : Up Advertisement Errors : 0 Label Retention Mode : Liberal Max PDU Errors : 0 Hop Count Limit : Disabled Bad LDP Identifier Errors : 0 Path Vector Limit : Disabled Bad PDU Length Errors : 0 Hello Hold Timer : 45 (remaining: 38) Bad TLV Length Errors : 0 Malformed TLV Errors : 0 Bad Message Length Errors : 0 Session Rejected Errors : 0 Keep Alive Expired Errors : 0 Index : 6 Attempted Sessions : 0 Targeted Peer : Not Targeted Shutdown Notifications : Sent 0 Rcvd 0 Admin Status : Enabled No Hello Errors : 0 Operational Status : Up Advertisement Errors : 0 Label Retention Mode : Liberal Max PDU Errors : 0 Hop Count Limit : Disabled Bad LDP Identifier Errors : 0 Path Vector Limit : Disabled Bad PDU Length Errors : 0 Hello Hold Timer : 15 (remaining: 10) Bad TLV Length Errors : 0 VLAN : v1 Malformed TLV Errors : 0 Interface address : 12.20.20.182 Bad Message Length Errors : 0 Session Rejected Errors : 0 Keep Alive Expired Errors : 0
This command was first available in ExtremeXOS 11.6.
This command is available only on the platforms that support MPLS as described in the Switch Engine v33.1.1 Licensing Guide document.
